benevans101
benevans101
- benevans101
- France
- 28
- France
Thanks W, I found that too and looked at the code. Unfortunately it's a bit beyond my skillset at the moment... I do think it would be great to have that translator as a separate tool, for those of us who want to use the saved data files in various …
Hi - done. You can delete it from here if you like. Thanks for your help - I've finally downloaded virtual box and will try to translate the file using the SpiSOP software, which promises to be able to do so. Can any of the other programs do this tr…
Hey! Yeah, steep learning curve, huh? I expect it is all quite straightforward for those who have done this sort of thing with other hardware or have lots of experience playing with Arduino... But if you're like me, it can be a bit daunting at first…
Yep, that's the tutorial I followed. I'm trying to do simultaneous EMG, EEG and ECG so that I can do basic polsomnography. So I'm assuming that using the MyoWare in the configuration recommended in the tutorial will then require turning it off at…
Great. Thanks for the quick feedback. I'm still toying with getting a Mark IV for a range of easy uses (if I get an upcoming grant I think I will!). But tell me - are your subjects lying in regular beds with regular pillows wearing the Mark IV? Cool…
Hey Retiutut & William - Thanks for posting the links and info. I'm interested in doing similar things. Retiutut - How have things worked out since your last post? Let me know what works if you've found some success. For me, given that profe…
