bcidecoded
bcidecoded
- bcidecoded
- UK
- 5
- UK
Does the saved recording retain timestamp gaps when USB samples are lost, or is loss only reported as a total? Keeping those gaps visible would help avoid treating separated samples as continuous EEG.
I'd start with a short task where you can log errors and response times, then test whether the EEG adds anything beyond those measures. What should the app do when it thinks your attention has slipped? The study app shouldn't become the distraction.
The same-day correction matters. Would you try a remove-and-refit session alongside one where the cap stays on? That could help separate placement effects from changes between recordings.
