ayau3
ayau3
- ayau3
- 24
@Andrey1994 Thank you for the quick reply! Sorry I'm very new to this and I'm unfamiliar with ring buffers, if I want to record 2 seconds of data, what should I set for the ring buffer size?
@wjcroft and @retiutut, thank you both for all of your help, I greatly appreciate it! Given all the challenges you both posed, I think I will try out brainflow instead. Silly question, but how do you set the length of recordings in brainflow? I've b…
Update: I did some debugging and now I think I'm a step closer, but now I'm getting the message "No compatible USB Bluetooth 4.0 device found!". In my device manager, Bluegiga Bluetooth Low Energy (COM3) is listed under "Ports" instead of "Bluetooth…
