attha
attha
- attha
- Bangkok
- 93
- Bangkok
* Aha! I see. Previously when I mentioned "two SRB pins", what I meant is two SRB2, one from cyton and another from daisy. * I think I used the word "spikes" incorrectly. I should say the "bad" board produces not as clean signals as other seven boa…
I followed the instruction of connecting daisy and cyton given in https://docs.openbci.com/GettingStarted/Boards/DaisyGS/ . Do you mean I should not use SRB1 in daisy+cyton?
* Yes, I connects all channels to the same scalp location, i.e. the two SRB pins, the CYTON's BIAS, and the 16 low NP pins. I used the pin PCB connectors with soldering to connect them. * Signals of the "good" boards that I think produce expected …
I sent the email to [email protected] for a week but have gotten no response yet. Maybe, I sent the email to the wrong address. Could you please inform me the correct email address? Thanks in advance.
Hi William, Thanks for your quick response. Yes, it has been working before. I will go to the lab on Monday to check the equipment. I went through the links, and found the test of the cython+daisy board by bridging the three pins with suspect chann…
@Shirley said: Hi Jonas, The hardware team has put the wifi shield on the list of near-term projects. Solution testing will soon be underway. At this point we don't know how long the fix + manufacturing of new wifi shield will take. Update…
Thanks for your quick response. I use python.
Hi William, I did some test in Windows 10 in which I opened no program (as far as I knew). In this test, I have an ESP32 to send a sine wave to the USB and the OpenBCI simultaneously. The shape of the sine wave from both devices arrives PC nicely…
Thanks William for your quick response .
Hi, I and my colleagues are conducting a research in which wifi shields are necessary. Might we kindly ask when they will be available? If the updated wifi shields could not be available soon, is it possible to get their previous version? Best…
Hi William, Thanks for the quick reply best, Atthaphon
Any updates? Hopefully it arrives before October.
