arya
arya
- arya
- 28
I was also looking to openVibe SSVEP basic experiment they have some inbuilt activation. But I have a mac, do you think openVibe running on a windows VM will hog the cpu. Generally Cyton streaming will have to done from macos to vm. Or I can try to …
I was using ultracortex IV at O1 and O2 position
Thanks, yes correct I will try that too. But before that I will try 10hz alpha wave. I understand about the accuracy perspective but first atleast some peaks around a range or harmonics should be seen with nearly accurate stimulation(pyscopy). As I …
ok sure, thanks for the help. I will try that out and write back!
I did not try alpha peaks, is it related in some way to SSVEP?
Hi William, As written in the post I tried with real LED diode matrix also at a specific frequencies of 6,8,10,12,15 hz but did not see the peaks. For screen activation I am using psychopy which can control the precise interval of the flicker if…
