antonM
antonM
- antonM
- Poland
- 13
- Poland
Sorry an update, the PROG button works, I had not turned on the digital read mode. Now my question is if I still need to use the optoisolation circuit? I have created it exactly how it is stated on the External Triggering page, but apparently this w…
Hi William, I hope you are well. I tried to resolder the J3 and J4 myself and tried to input the trigger in the different pins from D11 - D18. However, I cannot see any input in the Other channels (there are 6 "Other" channels in the excel spreadsh…
Hi William, Great, thanks for your help, very useful! Will get the board fixed then. Best, Anton
Hello together, I am trying to input some external triggers from auditory stimuli. When following the tutorial here: https://docs.openbci.com/Cyton/CytonExternal/, under External Triggering the hard way, it is described that some code needs to be i…
