andree1988
andree1988
I've connected the Cyton+Daisy to the computer terminal via a FTDI usb to serial converter(with serial port utility software).
I sent the commands " b s" manually and I got the following results.
My question is given that eight daisy channels have been identified why not Daisy board data in the log data and there are only 8 main board channels(there are only 31 bytes of channels 1~8 and accelerometer)?
Thanks for your helps.
OpenBCI V3 8-16 channel
On Daisy ADS1299 Device ID: 0x3E
LIS3DH Device ID: 0x33
Firmware: v3.1.2
Send " b " and after a short time send " s ":
41 00 C3 BF 73 C4 16 45 C3 D3 84 C3 AA 03 C3 9C 34 C1 9E AD C3 50 F0 3F FF FF FF 90 FF C0 0E F0 C0
41 01 FC CE 37 FC DB AE FC D8 2C FC C8 E8 CD F0 7E B2 7A E8 02 90 16 80 00 00 00 00 00 00 00 00 C0
41 E3 FC CF E2 FC DB F9 FC D8 83 FC C9 0A CE 73 34 B3 0C 98 02 8F B8 80 00 00 00 00 00 00 00 00 C0
- andree1988
- hong kong
- 17
- hong kong
I have no problem programming. My problem is getting 8-channels instead of 16-channels. When I send Command "b" for a cyton+daisy, this is the format of the received data: send " ? ": OpenBCI V3 8-16 channel On Board ADS1299 Device ID: 0x3E On…
Hi WIlliam, Thanks for your fast reply. I made the cyton+Daisy boards without the Bluetooth module. I was able to connect the board to the OpenBCI GUI 4.1.7 software via the WiFi module(ESP8266) and displaying 16-channel data plot. I need to tra…
