ali1632
ali1632
- ali1632
- barcelona
- 38
- barcelona
Hi billybobw, I have done this with several different approaches to handmade synthesizers in MaxMSP, using OSC messages from the GUI. You could conceivably do with PureData (opensource alternative to Max) as well. short demo of some of the bac…
Thank you!!!!!!This fixed it, at first glance. I will run another analysis on the timestamps but the stream is no longer jumpy and the bps rate is not bottoming out as far as I can see. I think I am back on track, thank you again.
Hi, William, @wjcroft Yes, I had seen it back when I set the system up. Thank you for the reminder. But.... I have driver v2.4.2 (May 2017), and this doc's last update is Dec 2016. The 2.3 described here is no longer the one recommended for OS 10.11…
And a short screen capture of the "jumpy" data and finicky usb connection. https://drive.google.com/a/maine.edu/file/d/0B42ODzFL8DD3Z0Y3UFFlc012c1k/view?usp=sharing
An update after analyzing the data output a bit more: Based on looking at timestamps in a pivot table, I am getting up to 5-7 packets per millisecond, when I'm getting them. But large gaps appear of about 460ms in length, with roughly 21ms of goo…
This is not a knowledgeable reply, but I had some similar spikes and found they generally disappeared when I moved to a space with less nearby electronics/wiring/lights, and shut off my mobile.
Anyone? Is there really no documentation other than the setup tutorials? Thank you.
Ok, posted. Thank you! https://github.com/OpenBCI/OpenBCI_GUI/issues/182 Cheers, Ali
A note for anyone else who is looking... I found screws, nuts, & bolts for the build, finally: What I ended up with is M2x20mm machine screws and matching nuts. These are a standard size but on the small end of what most shops carry, so I h…
Hi lagidigu, Actually I just got them yesterday and they fit! The harder one is maybe a little bit stiff, I hope not too much. Finally getting closer - everything is printed except the frame; my printer is just a little bit too small for th…
So I am also trying to find screws, nuts, and bolts locally. I am lost just trying to translate the sizes into local specifications so I can sort out what to ask for. Any successor failures you all may have had would be so helpful to hear about! A…
Hello!I'm also trying to assemble the ultracortex, in Spain. I'm here on residency from the US just for the summer, and OHHHH how I wish I had ordered the parts before I left home.... I decided to wait because my materials budget is provided here, b…
