alexi
alexi
- alexi
- 13
Thanks for the info!
Hi William, Thanks for your feedback. I actually ran a test driving with the audio jack before seeing your reply. Using this method, I was able to capture a very strong audio signal while simultaneously capturing EEG. My next step is to do the s…
Another update: (1) I tried running from the command line and no luck: $ ./pic32prog/v2.1.24/pic32prog -d /dev/tty.usbserial-DO00BLEV -b 115200 /var/folders/kj/1vv3kb595lb2bkk2s4f27qx40000gn/T/arduino_build_332800/DefaultBoard.ino.hex Prog…
The following is my system info, in case it helps. Mac OS version: 10.12.6 Arduino GUI version: 1.8.4 Arduino Board Manager: ChipKIT version: 1.4.3 Arduino AVR Boards Version: 1.6.20 Arduino Library Manager: OpenBCI_32bit_Library:…
Still no luck on fixing this issue. I'm trying to update the firmware now, but running in to issues here as well. I've been following the instructions here (http://docs.openbci.com/Hardware/05-Cyton_Board_Programming_Tutorial#cyton-board-programmi…
