aladdin
aladdin
- aladdin
- 102
I just used this:https://www.mathworks.com/help/instrument/udp.html
Yes
I was using the example code ReceiveData.m available on the GitHub page of LSL for Matlab. I switched to using UDP streaming directly from OpenBCI GUI because python and LSL was giving me too many problems...
I had to use an older version of labsetraminglayer and I only got it to work in Linux, not Mac nor Windows...
Thanks, I'll take a look at that! Alex
Thank you, I copied the dll file already, but now I get a new error. It seems function lsl_loadlib_ is missing...."Undefined function or variable 'lsl_loadlib_'. Error in lsl_loadlib (line 65) hlib = lsl_loadlib_(dllpath); Error in vis_…
Hi William, Thanks for your response. Sorry I used the wrong link, I am actually using the last version of labstreaminglayer. I got that error running a Mac OS. If I change the path commands to generate the correct path (instead of using the comma…
Try running an earlier version such as v2.2.0, it worked for me. http://openbci.com/index.php/software
