adar
adar
- adar
- 20
I think that is exact solution that I need. However I could not find the exact place for those because I am not good at ''processing''.
I would like to record the impedance values the ones showing when you press ''P'' or ''N'' button on the gui.
Yes actually i want to output both impedance and uV in csv format.
Yes I think It was the version problem thanks a lot. Where can i find the totorials for source codes to change recording type of a channel.
Hi again, I have downloaded processing and openbci_gui master. However in compiler whenever I press play button it gives `cannot find anything named surface`. What am I doing wrong?
