Default Avatar
abhinavjain
abhinavjain
Username
abhinavjain
Location
Singapore
Joined
Visits
4
Last Active
Roles
Member
Location
Singapore
  • Unfortunately, in a typical REM sleep one loop of eye movement may take up to 10 sec to complete. Thus, 0.3 Hz might be already too high. I am checking the paper you've shared in your previous message it could be something which can help us. I'll d…
  • Hi William, Thanks for the prompt reply. I see, I most likely will have to purchase a cyton board. I just bought the board couple of days ago and looks like I'll have to spend close to 500$ now :-(. Will try to play around with it and see if g…
  • I tired measuring EOG using the Ganglion board. While I was able to detect eye movement in both differential and EEG mode, the baseline was shifting back to zero and was not able to detect any low frequency movement on the OpenBCI GUI. Can someone…
