abhijith
abhijith
- abhijith
- 31
Sir @wjcroft, Still I didn't understand how to record ERP using the mentioned cap. Could you please explain it in some simple steps? Thank you.
Hi all,Since we are using the active dry electrode in Ultracortex Mark IV, I like to know what is the power range that we are giving to the electrode. Also, like to know what is the maximum frequency signal that the cyton board can detect? Kindl…
Ok sir, I will check. Thank you @wjcroft
@wjcroftThank you for the response Is there any specific range for the cyton board?
@wjcroft Thank you, sir, for your fast response.
@wjcroft I am using cyton board with 8 electrodes and It is working finely with GUI. What should I do?
Hi @wjcroft Sir, I tried the below code in python for streaming using LSL and I have a cyton board - the code is python openbci_lsl.py --stream But it shows the same error as for @squadus mention in the start of this discussion like - …
@wjcroft Thank You sir, I will try and will update my status
