aaronjoh
aaronjoh
- aaronjoh
- 14
I checked to make sure there wasn’t a problem with the input circuit - the transient voltage suppressor and RC filter. I also put the scope on the 1N and 1P pins. Photos of the board are: https://www.dropbox.com/s/dfx2i2dduo5b5mx/image1.jpeg?dl=…
Will do!
Yes, when running the tutorial, I get the expected results in all channels except IN1N - which only shows the 1000ms periodic signal.
Yes I am using all the pins that are closest to the main board (sorry I meant to type IN1N not IN1P). And by probing I mean I used an oscilloscope to look at the signal (compared to the ground) - so its not a OpenBCI_GUI issue, it appears to be a is…
