aarohi1510001
aarohi1510001
- aarohi1510001
- Ghaziabad, Delhi
- 13
- Ghaziabad, Delhi
@pushtheworld - Didn't find the actual solution but temporarily "After each use, I've to restart the processing software and load BCI GUI". Earlier I used to press "start system" button again and again for taking new data because there wasn't really…
Yes it works all fine - but only once, not when I Try to stream data after say 5-10 minutes. Its like its fine now and has some problem if once data stops streaming..
However, it actually doesn't recognize any usb after being used once, that one time it works all well though. I guess it tell there isn't hardware problem and with the OS, it's freshly installed, earlier I was using Windows, its just a month or two …
Okay, Thank You, I'll check the Cyton again to make sure there isn't a problem with it.
Actually it works well with another Ubuntu device sometime back. There can be error in my system but not able to detect the error, please help.
Okay I will send the screenshots asap..What is there's some error in the drivers?
Yes it did run and used sudo for that.Its works fine only once, next time the usb doesn't show in the list.
What if the GUI recognizes the dongle only once and not anytime thereafter? Even though the blue light appears on both the components but it never says system is up in ubuntu 16.04?
Processing 3.3, none other version worked properly on linux, except this one!
Hey, I have a similar issue, my dongle gets connected for the first time though and it shows "system is up" but when I try it again, the usb port doesn't show up. I Try shutting down the laptop as well but same results even after restarting. Its aro…
Thank you for the help. Yes I searched in many research papers, though they all tell different positions. Is it because theta waves generally cover the entire cerebral region?
Can you help me with finding the electrode position for Cortical Theta Waves for drowsiness state, I searched everywhere but didn't find it. I'm a learner and its very important for me. I'm using CYTON 8-BIT. Thank you.
