aaravsharma
aaravsharma
- aaravsharma
- 28
Thanks for sending it over. When I changed the BIAS and SRB wires from it being attached on the bottom to the top of the cyton board, then all of the electrodes starts showing not railed as I want it. However, then I see a lot of noise in the data, …
Hi Wjcroft, Thanks for your response. I already managed to get Brainflow connected and got the real time plot example to work (would this help?) Is it possible to just get the EMG Data directly through the Brainflow Library though?
Thank you
Hey wjcroft, I am running into another error and I can't find the solution of it. I am trying to post my question on the OpenViBE Forum page, but I need access to do so, and their Board Member hasn't approved it yet.. Could you help me in prov…
Thanks for sending those links over, I'll check out the first couple of links you sent and the forums if I still can't get a solution. Wow, yea 2015 was long ago!! Thanks for your help again!
Hi wjcroft, thank you for your help in directing me to Jeremy's tutorial. I am halfway through it, although I ran into some confusion. There are 2 files he talks about 'mi-csp-0-acquisition.xml' and 'mi-csp-1-acquisition.xml'. I needed to go into m…
Oh yea, that's great then. Thank you!!
Okay, I will add more electrodes to my motor strip, and complete the tutorial from Jeremy, thank you!!
I am also adding more electrodes focused around the Motor Strip(since I am trying to do Motor Imagery either way).
I just checked out Jeremy's tutorial and I was wondering if there was an alternative to this, since he was detecting clenched teeth, eye closed, and eye blinks. Since I am controlling an Exoskeleton, I don't want the controls to be those, instead, I…
Okay, I'll take a look at that. Right now I have the Cyton + Daisy, so I have 16 electrodes. I am going to move some of the electrodes from the frontal lobe to the motor strip(since other tutorials have that). Also taking a look at VEP.
Yup, in the modified headset, I made sure to add some around the motor strip as well. Thanks for confirming that! I'll also check out that older tutorial you sent. By the way, most of the electrodes are at the frontal lobe. Do you think that there w…
Hey guys, I am also following the tutorial for motor imagery, does anyone know where to find the file called: motorimg_calibrate.py ?
Hi there, is there any solution to this problem? I am also trying to find the motorimg_calibrate.py file.
