a1eks
a1eks
- a1eks
- 64
Thank you for your detailed response. Of course, optical triggers are the best way to align markers with the signal, and it's been used even with much more expensive hardware. However, the problem is real-time processing and how to handle the dri…
thnx for the fix. Now it works!
In the new version, there is an issue with the impedance measuring again (Cyton+Daisy). Apparently, it seems that in the https://github.com/OpenBCI/OpenBCI_GUI/blob/master/OpenBCI_GUI/HardwareSettingsController.pde in the method toggleImpedanceChec…
Sorry for the late response. I have firmware v3.1.0. I tried using terminal emulator and commands are accepted and work well. However, with OpenVibe not really, there is no response there eighter. It seems that OpenVibe driver needs to be updated!…
I will test it more extensively next days and write here if it works or not. What I know for sure is that v3.2.0 freezes the GUI when I want to start LSL streaming on standalone app.
I tried to use the LSL widget and everything freezes?! In any case, maybe the best solution would be to implement support for Acquisition Server for OpenVibe that can directly be used with WiFi Shield. In my opinion, apart from the main purpose for …
