Yoshi
Yoshi
- Yoshi
- Japan
- 22
- Japan
Hello. I thought I had misinterpreted the graph. Even though the peak of Alpha amplitude is low, if you sum the amplitude of each frequency (Alpha : 8-12Hz), the value would be high enough. Well, I might be wrong because I don't know exactly how…
Thank you William @wjcroft I sent an email to OpenBCI.
Hi, William @wjcroft. Thank you for your comment. Yes, I used the exact same touchproof electrodes on both systems: Ganglion and Neurobit Optima. I tried diffrent channels and cables, but I still got around only 2 microvolts. I also tried alph…
