Xp0
Xp0
- Xp0
- 140
Hello Zimmerman99, I actually ended up using a similar software myself to analyze serial data a couple of months back. Good recommendation nonetheless! For any users interested in connecting their OpenBCI to an arduino via serial port (usually…
[original thread title: Regarding the value that the Focus or Networking Widget sends of serial port.] Hello, I recently had the chance to attempt yet again to get this seemingly trivial concept functioning: the focus widget as well as the t…
Thank you so much! This actually gave some response as opposed to the others. After checking I believe i may have made in error in baud rate, though by default the drop down menu on the GUI reads 115200, you have to open it up and click on 115200 ot…
Thank you so much. I'll work a bit the concepts and see how that turns out.
Sounds like an interesting concept. Would you care to elaborate? My end-game here is to be able to manifest measured EEG using the ganglion into physical hardware, a task which seems well achievable with something such as an arduino. I have experi…
Additionally, is there anyway to manipulate data being streamed from OpenBCI GUI to the arduino so that the arduino itself can generate an output? Im a little lost in terms of how I can do anything with streamed data with arduino IDE (i.e. Measured …
Wow. Thanks for the info! Cannot believe linking the GUI to serial was that simple. Now, it is to my understanding the baud rate for an arduino which I'm using should be around 9600, this doesn't not appear to be an option on the current widget, a…
