Wonkybadonk
Wonkybadonk
- Wonkybadonk
- Idaho
- 17
- Idaho
- Interests
- BCIing and music
I think I was actually able to get the OpenBCI_Python to talk to the Ganglion in the Ubuntu guest through the CSR dongle using BLE as of a few minutes ago. So I'm not sure that native Linux is required as long as you pass the dongle through to the g…
You're good the confusion was on my end. The comment at the beginning of openbci_c.c just said 'This program provides serial port communication with the OpenBCI Board.' I assumed Ganglion was included in that using BLED112 and after the Code 412 err…
I think I'm as confused as you then. I've purchased a Ganglion, a CSR dongle and BLED112 dongle. When I launch the OpenBCI_C test.c with the BLED112 hooked up and run as sudo I receive the following after I fiddled with find_port() a bit: Using po…
@fwende Seconding @wjcroft as far as perusing some existing code that streams BLED112 to Ganglion. github.com/OpenBCI/OpenBCI_C might also be enlightening if not so wonderfully OOPed as a java implementation. I've been able to get this streaming dat…
Hi William, Sorry for the delayed response! I've just been using a fork of the OpenBCI_C driver repo that's on OpenBCI_C. Mr. Keller merged one of my pull requests making some minor changes to find_port() (github user: zthurman) I'm awaiting the…
Hi William, Thank you for clarifying! I misunderstood, I'll start digging in to see if I can cobble a working implementation with the CSR together Thanks again for the response and for continuing to support us in the forums!
Hi ivanELEC, I'm working in an ubuntu 18.04 VM on a Windows 10 host using the Bled112 dongle to the ganglion so your mileage may vary significantly using a Cyton, especially if you're using a wifi shield. The virtual network adapter passthrough …
I'm working with the C library on linux as of today with the Ganglion, I was able to get the Bled112 dongle to work and start a data stream by supplying /dev/ttyACM0 to set_port(). However I can't seem to locate the CSR dongle in linux. I've tried C…
