VinnyMS
VinnyMS
- VinnyMS
- Canada
- 27
- Canada
Can open bci make a deal with Microsoft to embed the ganglion in their motherboards. To create bci ready computers
If you make edits can it work as a server
Is it possible to connect to the Ultracortex "Mark IV" EEG Headset through a Wi-Fi satellite antenna from space Can the satellite connect to pi server
@wjcroft said: 100 meters (above link) is the length of a football field. In general, when using EEG equipment, you want the laptop to be within easy reach of the person from whom you are gathering the EEG. Because the laptop is used for recordin…
Very good, thanks a lot
Can a Wi-Fi antenna be connected to the dongle to raise the distance limit Like weld it to the Wi-Fi antenna and attach it together
how to raise the distance limit? pc to sensor worn
can a wifi antenna raise the distance between sensors you wear on your head to the laptop receiving it
where can i find that? i want to buy
in theory is the there are many natural sources of brain waves. We can figure out how to electronically generate brain waves using electric currents. Two components are required for brain wave communication: a transmitter and a receiver. Brain wa…
the antenna has to be very powerful to compensate
the antenna has to emit powerfully to connect to the brain, even if EEG is weak it can connect. alot more weaker signal can connect to a very powerful antenna the antenna creates a connection first then it reads the EEG
as soon as we deal with waves, long range antennas have the capacity to read the waves. it's brain waves so they can be read with an antenna as soon as the waves emit, they can be read. the brain in theory shows up through software as a wifi network…
There is a way to read the brain in plain text. You need the eeg data In csv format. You need to count the frequency of each eeg value. You create a list of top frequent eeg number. You replace the list with a second list of words. Eeg numbers becom…
