Turpin
Turpin
- Turpin
- Tokyo
- 49
- Tokyo
Hi William, Do you know if i can use the RFRX and RFTX for a serial connection or are they already used by the CYTON ? Regards, Turpin
Thank you very much William, You are doing an awesome job on this forum.
The problem is that i didn't find any arduino code exemple for CYTON. So i'm lost with myself :-( Buying the Wifi module is the last solution for me ...
Thank you for your answer, I saw that some pins are not used on the CYTON (D11, D12, D13, D17, D18). The CYTON is Arduino compatible, so it should be possible to create serial connexion between the CYTOn and an Arduino card. Here I talk about a…
