TorstenLO
TorstenLO
- TorstenLO
- Denmark
- 21
- Denmark
Thank you. However, I have delivered my headbands + cyton board to my project partners who are going to use it, so I will not be able to do anything in the near future.
@wjcroft said: Philip has found the fix! A newly built GUI version should be available shortly. Will update with the number / download here. That sounds very good. Thanks for the looking into it :-)
@retiutut said: I've added this thread as supplemental info for https://github.com/OpenBCI/OpenBCI_GUI/issues/1204. Some of my measurements are similar to what is reported in the other thread, though some are also very different. As examp…
So as I understand it, right now we do not know whether it is the hardware or the software that is not working as intended? Do we have anyone that can confirm correct measurements from the cyton signal widget? If IN1P-IN8P should be bussed together…
I wrote to support and they asked me to make measurements with conductive gel/paste and send pictures of time series measurements. I started doing that, and decided to go back to doing exactly the same as explained in the EEG headband kit guide, in…
Sorry, I just understood better what you wrote. Yes the settings are the default of x24 gain, normal input, bias included, SRB2 on, and SRB1 off, for all channels.
Hi William I am familar with the hardware settings panel. I have been using it to change the gain and turn bias on and off. However, I have not changed anything else and I have only used the "send" function. Never the save or load functions. Als…
