Tilano
Tilano
- Tilano
- United States
- 22
- United States
Thanks for your answer So I did what you said, I start openBCI, went to network/OSC and then set the Port to the same number as I can see in Neuromore (in Settings/ OSC Server (and actually there are two numbers "Input UDP port" and "Target UDP por…
The open GUI works ok on the mac and I am able to connect to the ganglion board, I was trying to run it on windows because I want to interface with brainBay (which works only on windows). My goal is to do brain machine interface using the beta ba…
I am running window as administrator on a virtual machine on a mac. the idea is to connect to a ganglion board.
Hi. I am having the same error on Windows 10 and I am using the version v1.4.6-win-64-64bit of the HUB, Any idea of how to fix it? Thanks!
