Default Avatar
Thilina
Thilina
Username
Thilina
Location
Toronto
Joined
Visits
13
Last Active
Roles
Member
Location
Toronto
  • Sorry for the long delay on my follow-up. I wanted to make sure that I would avoid misguiding others on the forums looking to do similar projects. I have been able to recognize the different motions I wanted, however, there are some issues with m…
  • Hello again William, Thank you for your encouragement! I have not tried the disposable electrodes because I expected to make several mistakes in the process of this project. I did of course, and had to apply and reapply the Dryodes several times ov…
  • I bought a new laptop and I have the GUI running and will start collecting data soon. I'm not sure what happened that suddenly prevented my desktop from running the GUI and .wav audio should work fine. I'll look into more troubleshooting when I h…
  • Thank you William, Although my audio outputs/inputs have not changed since I last had the GUI working, I currently am using Bluetooth headphones (Sony WH-1000XM4) as output and sometimes also input (I also have Microsoft LifeCam webcam for input). …
  • Thank you for the very quick reply William! I did try both the driver options as suggested but, this did not change anything sadly. I have gone through each of the audio/sound related menus in Device manager and confirmed that they each have the la…
  • Hello, I am also having this problem. A few months ago I followed the steps suggested in this thread and others and resolved it. The past few days I have been using the GUI I had no issues. As of this morning however, the issue has come back and I…
