Default Avatar
TFNANO
TFNANO
Username
TFNANO
Joined
Visits
24
Last Active
Roles
Member
  • Thank you for your comments and support!  @jfrey, 1b) I have not observed any error messages that appear in the console during openvibe server, but I will pay attention to it more. I believe that this "emergency reconnection" feature is what allow…
  • Hello,  Yes I have tried to save to SD card, but because the software stops acquiring it also stops saving to the SD card. Is that suppose to happen? Or should the board continue saving to SD even when the acquisition software stops running? Is th…
  • Could this be a bug related with the GUI? Maybe there needs to be memory clean up? I am not that familiar with Processing garbage collection, so how should I check if it's a memory issue with the visualization? Would throwing a System.gc() somewhere…
  • Hello @chipaudette @conor_obci, Here is an update. I've tried running the experiment an another Windows 8 computer and on a Ubuntu 14 computer; it is still has the same issue even on these OS - signal montage freezes after 1.5 - 2 hours, the red l…
  • Hey William,  32-bit board with Daisy Module (but I'm currently only using 8 channes), Windows 8 computer, 4 AA batteries in the battery pack that came with the kit. I have not tried running it on another computer.  Currently the GUI saves dat…
  • I think the best way to go about this is to convert the signals into EDF format, since there are many open source software that read EDF format. Do you think that would be best? If someone has used/converted to EDF format previously, how can the si…
