Sotiris1
Sotiris1
- Sotiris1
- greece
- 28
- greece
I would just like, in the context of the project I have undertaken, to procure a development board for the connection of sensors that will measure various parameters. Ideally I should build a board just because of the time limit and because I am a b…
Thank you very much for speedy response. I have another question that I asked you before,is there a development board from your company that supports all these EEG ECG measurements and at the same time has ports / GPIOS for connecting analog or d…
Thank you very much for your speedy response !!
So to see if I got it right, can I use these auxiliary pins / GPIO to connect analog or digital sensors (not at the same time) ??? If not, is there a development board from your company that supports all these EEG E C G measurements and at the sa…
Good morning, I probably did not explain it well because you did not understand my confusion. Generally I want to do a standard ECG with the cables and electrodes using the cyton bio-sensing board. My main problem and question is if there is a be…
Thanks for the prompt reply . Because I am quite confused because I have no general experience in designing and operating such systems, I basically want a belt to be worn on the patient or user's body and just connect the electrodes and cables I …
Thank you very much for your prompt response and your valuable help to my questions. However I would like to ask you one more thing regarding the electrodes that are for measuring the activity of the heart: Specifically, do you know if there are el…
hello , Based on the Project I have undertaken, I want to get the cyton bio-sensing board from your company, because I believe it is very close to my project and I believe it will help me a lot. But I have some questions: 1) If I understand correc…
Thank you very much for your prompt response and for your help Yes I know that there are many types of electrodes but my question is basically to what extent the electrodes of the encephalogram will be compatible with the specific AFE, is there a…
