Skalbe
Skalbe
- Skalbe
- Latvia
- 292
- Latvia
- Website
- www.waveforgeentertainment.com
- @zebnickis
- Interests
- The now of life and human condition, god in self, convergence of knowledge, interdisciplinary and emergent understanding, accessing spirit through technology, expanding awareness of self, movement
- juris.zebnickis
Hi William, While testing with a usb extension I found out that the interference would appear if the dongle is nearby the same usb port as where my Oculus VR is connected AND if the Cyton is on my head. I moved it around on the extended wire and if…
Ahh sorry I get it now, the purpose of the wire would also be to distance the dongle from ambient conductors and fields. Its just like this now, but it did work in this setup for a very long time and did not drop samples. I still have to resolder th…
Hi William! The dongle is just plugged into the usb drive. It is not touching anything else, while the Cyton board is in contact with just my hands or a wooden table. Will try the battery change.
Hi guys! I was not aware of that widget. Thank you! So I charged up my battery and made sure to reconnect it to the charger a few times as it would show the red led after the first few reconnects after it had shown green. Could this mean that my b…
This also could depend on your own brain physiology. I have friends, whom I have tested who do not exert any idle alpha rhythm with eyes closed.
@mbamontehttp://openbci.com/forum/index.php?p=/discussion/2223/is-my-cyton-broken-non-responsive-after-attempted-firmware-upgrade#latest
When was the last time the dongle worked and what was the last thing you were doing with it?
Thank you, @wjcroft for the responses. You, sir are truly a scholar and a gentleman. I took a long walk and the big picture came together. It all works perfectly now. This is the order of steps I took to successfully update from 1.x.x to 3.x.x…
Hello @wjcroft!What I did: 1) I installed Arduino 1.5.8 and got the RFduino and the OpenBCI_Radios libraries. 2) I soldered on the headers onto the dongle. 3) I plugged in the dongle, set it to Reset and uploaded RadioDevice32bit with the line ra…
What I meant was I did what follows:Upload DEVICE Radio Firmware Version 2.x.x (Fall 2016) until: Program DEVICE Radio with OpenBCI Dongle and then: Upload HOST Firmware Version 2.x.x (Fall 2016) I have now acquired all the third party hardwa…
I mean I did both the Device and Host, I just didn`t Program the device. In any case I`ll have to find out. Thank you. I will update with the results.
Hello, Mr. Croft! As far as I understand I had `flashed the Pic with DefaultBoard`, but it seems that my firmware was initially version 1.x.x and before I can get to 3.x.x, I have to upgrade to 2.x.x first and this includes the Device and Host pro…
Neat! Will try this out.
If you can, do let us know if you find any hard correlations during your development.
Hi, klam!As you already have found out, alpha waves are not a given. I have found that numerous of my test subjects cannot produce reliable alpha waves, even though it is allegedly the 'hello, world!' of bci hacking. Then again, my own alpha waves a…
I see. That is indeed rather bulky.I will try contacting the FRI. Thank you!
Figures.Thank you, Mr Croft, but would it be possible to arrange some kind of an order through OpenBCI or should I write to Florida Research Instruments directly?
Edit: I`m looking for a spikey electrode with the same tiny plug on the back as the flat snap-in ones. I`m looking to integrate the snap-in wire design into a headset and I know that the headband kit has the sort of snap-ins where the electrodes go …
Sorry for not being clear. What I`m looking for is the flat snap electrodes that come with the headband kit, but with spikes.So these here https://www.fri-fl-shop.com/product/disposable-reusable-flat-snap-eegecg-electrode-tde-202/ but the kind t…
Thank you, but then from what I`ve seen, OpenBCI cables are NOT shielded? Yeah I did that. No response. As to the resistance, that is what I will attempt then. I want to use the actual skin resistance as a factor multiplier in emotion recogniti…
Thank you for the prompt response, Mr, Croft!Just to clarify `shielded` means that its protection is just the wire? Also are you affiliated with the OpenBCI in some way? I`ve been trying to contact them with no avail. I`m asking just because you se…
I do all the signal processing with the OpenBCI GUI that's running there in the background as you can see.For the Unreal engine I just wrote a custom socket networking module that receives from the OpenBCI GUI. I also rewrote how the GUI packages da…
I need this!
The latest GUI V2 seems to be working great though.
As far as the current tech is concerned, there are no cortexes. We only get raw EEG readings in large quantities over relatively huge areas of resolution and it's up to us to 'assign meaning' to the reading from an area according to what we know abo…
I would like to have a helmet that does all of those things too, but currently the technology is very fringe and available in parts.I don't entirely understand what you mean by all I/O processing going through the brain. And the screen in the curre…
Hello Abe! I love to see how people think about emergent technologies.I have been on this for a few years now and have so far found nobody else who is going the same direction. I've found numerous combinations of software that could allow for such …
Update: Neuromore representative confirmed that there is some kind of a serial comm problem on their end.
Thank you, wjcroft.I cross-studied OpenVibe as well as BrainBay and discovered that both work as intended. I built some custom BrainBay designs and tried recreating them in Neuromore. Neuromore still has a better communication (for me) built in so I…
I read that thread and understood the theory, but my technical application in Neuromore is lacking I think.What I have is the starting classifier that comes with Neuromore for the OpenBCI and nowhere in the setup or any tutorial does it say anything…
