SimonPei
SimonPei
- SimonPei
- South Korean
- 70
- South Korean
Hi William, Thank you for your continued support. Following your advice, we ran multiple recording sessions in electromagnetically quiet locations. As you can see in the figure below, the first few seconds of data contain no abnormal peaks, and t…
Hello William, Thank you so much for your last reply. It was the final key we needed, and we've had a major breakthrough in our understanding and process. We are happy to report that the issue is now resolved. You were absolutely correct. The …
Hello William, Thank you very much for your detailed reply and for providing that forum link. This is incredibly helpful and we believe we are getting very close to the core issue. We have a couple of follow-up questions to ensure we are under…
Hello William, Thank you again for all your incredible support and for providing the previous version for us to test. We will proceed with testing that version shortly. Before we do, we have one more critical discovery to share that we believe…
Hello OpenBCI Community, and thank you for your invaluable advice. Following your strong recommendation, we have conducted a series of experiments to rigorously test for environmental EMF noise. We collected data in four distinct locations: our l…
Hello OpenBCI Community, and thank you for the prompt clarification. You are incorrect. The Ganglion data stream provided by both the GUI and Brainflow is in microvolts already. No conversion is needed. This is very helpful, as it conf…
Thanks William!!!!
Hi William, Thanks again for all your help. I’ve got one more question: our 3.7 V 500 mAh battery only lasted about four hours, so I’m wondering how long a full recharge should take with the charger included in the Ganglion Board package (https:/…
I saw on the battery that it’s rated at 3.7 V, 500 mAh. Thank you very much!
Hi William, Thanks so much for your help! We actually purchased the Biosensing Starter Bundle (https://shop.openbci.com/products/biosensing-starter-bundle), but when I check the Ganglion Board page (https://shop.openbci.com/collections/frontpage/…
It works now. I just ask this question for my friend. Thanks William!
Hey William! Thanks for your suggestions!!!
And in the Band Power window at the lower left, the five types of brain waves remain unchanged. I tried all the smoothing options, but nothing changed.
Hey William, I find no time series differences in the frontal electrodes when you blink or clench your jaw (see figure).
Hi William, Thanks for your help and your teams support!
Hi William, Thank you so much for your detailed reply, guidance and support!
Hi William, Thank you for your detailed explanation. We purchased the Biosensing Starter Bundle (including the Ganglion) on June 09 of this year. I understand from your note that as long as the sample index increments by 1 consistently, I only ne…
Thank you, William! I'll submit a smaller image next time. After turning all four switches to the down position, I noticed almost no change in the data on the OpenBCI GUI. Although I followed the tutorial you recommended (https://docs.openbci.com/Ad…
Thank you for your reply. * I was only able to move the switch slightly downward, but I’m not sure what exactly counts as the "DOWN" position (see the attached image for my current result). * Yes, I have connected the two electrodes clippe…
Hey Willam, thanks for your reply. I noticed that each of the SW1–4 on the mainboard has a layer of transparent plastic on its surface (I just got this device recently). I tried to pry them off with my fingernails, but I wasn’t able to remove them. …
My leads and pins are connected a s shown in the figure
