Sifeng
Sifeng
- Sifeng
- China,Beijing
- 55
- Website
- www.brain-intelligence.cn
- China,Beijing
the picture:https://www.dropbox.com/s/8jp3pyzr3u1yhk5/16 Channel.jpg?dl=0
Re-uploaded OpenBCI_32bit_SD code and it works wrong still.16 channel for start system.The error still is :Init timeout verify your serial/com port.Power doen/up your openbci&USB dongle,then retry initialization.The processing error is:don't dra…
I chosse 16 channel for start system.The error is :Init timeout verify your serial/com port.Power doen/up your openbci&USB dongle,then retry initialization. But I choose 8 channel for start system,everything is ok. My OpenBCI board is 32 bit …
According to the docs(Upload_Code_to_OpenBCI_Board), I upload the 32bit code to my OpenBCI 32 bit board.The following error occurred always. Binary sketch size: 54012 bytes (of a 122880 byte maximum)avrdude: verification error, first mismatch at by…
Thanks for your reply. Now, the postion of switch stuck is on the PC.I know what to do!
Where I can download the code of OpenBCI 16 Channel Dasiy.
I can't upload code of 32 bit 16 channel for my openBCI dasiy.But upload code for only 32 bit is correct.
Thanks for your reply. So,I need set sample rate=125Hz for 16 Channel data.But for my experiment,sampling rate required 500Hz.
Same problem for me.
Thanks
