Shaima616
Shaima616
- Shaima616
- United Arab Emirates
- 25
Dear William, Thank you very much I will go through it Shaima @wjcroft said: Shaima, hi. Please see this related thread, https://openbci.com/forum/index.php?p=/discussion/2418/gui-focus-widget-algorithm-question Als…
@retiutut may I ask a question please? for the brainwaves value, are those numbers the amplitude of each frequency ? and to say a certain frequency is higher than others at a certain time, what would the number approximately for that brainwave typ…
Dear Billh, Well, we thought about streaming directly to arduino because we wanted to take real-time data that is happening to the user and then perhaps write a code which could do what you mentioned, we are researching about the possible simple wa…
Thank you very much ! we will try our best after studying the way more. @wjcroft said: https://www.google.com/search?q=how+to+read+and+parse+serial+stream+on+arduino
Thank you very much ! will look into it and try what we can ! @retiutut said: Here is an example of the GUI v5.0.4 Networking Widget BandPower data stream over Serial using Ganglion or 4 channel Synthetic mode. [Channel Number,Delta,…
Dear Mr.William, Yes we actually did this but we were confused on the arduino coding , how do we call the streamed data. Thank you Shyma @wjcroft said: Bill, thanks. Yes, Shaima, the GUI Networking Widget can do all of these s…
Hello! yes we have read your project (actually I have read it many times ) and we are really impressed by your work!. Initially we could not use it because we did not have the older openbci version and we had to mention an ongoing avaliable system…
@Billh said: Do you have OpenBCI's GUI running on a computer connected to the board? If so, why not do all the processing on the computer that runs the OpenBCI GUI and just send the result as an on - off signal to the Arduino? Yes I do h…
@retiutut , or anyone who can help please...
