Default Avatar
SeventeenChen
SeventeenChen
Username
SeventeenChen
Location
Shenzhen
Joined
Visits
14
Last Active
Roles
Member
Location
Shenzhen
  • William,thanks, Good idea, and we tried your suggestion at once, it made just a little sense, but waveform synchronization still existed, compared with connecting two subjects' ground, the  phenomenon disappeared a little. Regards, Chen
  • William,thanks, The cables were connected to cython individually.  The closing eyes effects were observed in two channel individually without the interference of the other. But the SSVEPs displayed on outr computer could be affected by the other. …
  • Thanks,William, We have tried to change the setting it in GUI, but it sitll can't work well Regards, Chen
  • Hi,William,  Thank you~~,and I have tried to connected to serial port with openbci_matlab.py, in chip, he didn't turn BAIS off, and we have tried to turn BAIS off  or  keep BAIS on, but both made no sense. Regards, Chen
  • Hi, William,   Could you tell how to programming the cyton SDK to control the serial port? Regards,         Chen
  • Hi, William,   We have tired to adjust my OpenBCI_GUI settings to disconnect SRB2 (and SRB1) from the common reference bus, but it seemed make no sense.   We have read the website about cyton SDK, but we don't know how to programming the serial po…
  • William,hi, Thank you very much!It‘ll be helpful to our experiment. Regards, Chen
  • William, hi,  I have read the blog on the EEGHacker blog about use SSVEP to control the Hex Bug and Shark attack. I use the same sets in his Hex Bug experiment, but we can't view  spectral response with peaks, of course the SNR is not enough. So we …
  • William, hi, Thanks for your reply. I will try cups with paste. If you have more details and suggesstions, welcome to comment and contact with us. Regards, Seventeen Chen
  • Billh, hi, Thank you very much for your comment. I will try the O1, O2 at once. The suggesstion is very great! If you have more details about the experiment, welcome to comment and contact with us. Sincerely, …
  • William,hi, I'm pleasant to receive your detailed and abundant answer. The most important is the stimulus in SSVEP are better to use LEDS with crystal.  The other question is the gel electrodes. Are they the golde cup electrodes with Ten20 Condu…
