SecretSquirrel
SecretSquirrel
- SecretSquirrel
- 4
The Ultracortex has all the 10-20 sites (sockets) for 19 channel, but normally is only configured for 8 or 16 channels. If you email to contact at openbci.com, I believe you could order 3 additional electrode holder units. Thank you so much …
@Rod said: SecretSquirrel Thanks! Have you done this? It sounds as though you might have...? I do a lot of work around physiological signals of the human body. I also do a lot of work around mathematical physiology, utilizing systems of d…
@retiutut said: https://www.kickstarter.com/projects/emotibit/emotibit-0?utm_source=kickbooster-direct&utm_medium=kickbooster&utm_content=link&utm_campaign=a877f1f9 5 days left in the Kickstarter campaign for Emotibit, and this…
@wjcroft said: Instead of the $1700 Empatica, consider using Emotibit instead ($200). It was designed by Sean Montgomery, staff member here at OpenBCI. https://www.emotibit.com/ There is a comparison chart about halfway down the pag…
This has already been done with the OpenBCI headsets, in conjunction with an Empatica E4 wristband, and it has been published in a very reputable journal. The Empatica E4 wristband is a very useful device that measures electrophysical signals such a…
