ScottThomasMiller
ScottThomasMiller
- ScottThomasMiller
- Brooklyn!
- 45
- Brooklyn!
Andrey! William! What's up? I've been swamped lately but I can carve out some time to assist.
How exciting! Thanks mkeeter. I will check it out. After 8 months I finally heard back from Apple Feedback Assistant regarding this issue. Their reply is: * Latency timer can be configured with ioctl IOSSDATALAT. * buffer size is not configur…
Hi Calvin. Still no help from FTDI. I had to give up and move on. My team decided to live with the jitter we have, for now. We are only at the very earliest, proof-of-concept stage, so we don't yet require extreme precision and accuracy. For …
William is correct. It might be that FTDI is having trouble getting the necessary entitlement from Apple. Or they've essentially closed shop and have no one around who remembers how to code
It's working, but on the iPad simulator in Xcode. The simulator can see the /dev/cu* device when the dongle is plugged into my MacBook. But when I deploy my app to my iPad and plug the dongle into it, there is no such device present, and as a resu…
I saw your email. Thanks. I used my local ID to sign it, but apparently that's not good enough. The internet seems to think I need to pay $100 for a real Apple developer ID, and use that to sign it instead. I did the following to sign it: …
I'm working with a support person named Cameron via email. He is responding quickly. I asked him which built-in driver I should unload. He replied that he needs to verify with their Mac team in the UK. While I wait, I am trying to hack this ou…
Hi William. The stuttering happens with the OpenBCI GUI, and with my custom Swift app which uses BrainFlow. Is there no other workaround or solution for the M1? Maybe running in Rosetta mode, or using the WiFi shield? I sent an email to suppor…
