Rushda
Rushda
- Rushda
- Pakistan
- 14
- Pakistan
Yes,we did flash board with the above stated line,the device and dongle radio were flashed successfully. The firmware V2 however resulted in the error of 'No device found'
We tried V2 firmware. It gave the error 'No device found'. Then we tried V1 firmware again and the device started working. Although the device is working, we are still not able to figure out what the issue was. Thankyou for all your help and support.
We have tried following for OpenBCI 32 bit in the given order: Flashing device radio (successful) Flashing dongle radio (successful) Burning bootloader on the device (PIC32MX250F128B in MPLAB IPE) using PicKit 3. (Successful but since then the led o…
Yes I set it to the correct radio channel. I updated the firmware in both dongle and device, and it was a success. But there is still no data in the live stream. I now plan to update the hex file in boot loader using Pickit.When I load code in to th…
I have tried different laptops, but somehow it is not working. I flashed dongle as well, but no results . Anyway, Thankyou for all the suggestion.
I checked the com port on cmd using command netstat -a -n. It showed that the port was active.But when I used hyperterminal to check, it stated "Failure: Communications timeout - Device failed to poll Host $$$". Does it mean the port is not working…
I have checked that the COM port is working, Moreover I have been using multiple laptops so that is not the issue I guess. I have checked for the FTDI drivers and they are installed already. The LEDs for dongle and mainboard are both up. I have not …
