RomainP
RomainP
- RomainP
- Belgium
- 43
- Belgium
Thanks a lot William! It's greatly appreciated!
Hello William, Thanks a lot for your suggestion, this indeed seems to be a viable way to achieve this detection feature! With the impedance check I have about 500kOhm when in use, and 5000kOhm when not in use, and unlike the railing values this…
Hello wjcroft, thanks for your response! The problem is that I'm trying to use my EEG headset (Ultracortex Mark IV, cyton board, 8 channels) in a node.js application, which isn't supported by brainflow at the moment. So I'll have to figure out ho…
Found a similar issue here :https://openbci.com/forum/index.php?p=/discussion/2738/windows-openbci-gui-freezes-resolved ==> It's a problem with read/write access for the program. I tried running OpenBCI GUI as Administrator but this didn't sol…
