RazanAbdulla
RazanAbdulla
- RazanAbdulla
- India
- 99
- India
Hi I've used Cyton with dry electrodes for my experiment. I'm getting amplitude between +/- 100microVolt for most of the trials. But sometimes the values gets over 2500microVolt. Is this because of some problem with my hardware or is it normal? I'm…
Hi @wjcroft, I did some tests with this tutorial on P300 with Cyton, Not the exact arrangement ie, only with video as stimuli and not using a photoresistor to provide an additional input as I just wanted to analyze the changes in signals according …
Hi @wjcroft, I've done some experiments with visual cortex signals using Cyton board for classifying signals corresponding to different visuals. And I couldn't get any significant difference in signals, Is it because the signals are weak(from visu…
Hi @wjcroft, I've gone through the Mindaffect docs regarding SSVEP. I have this doubt(I'm definitely not an expert), if we're using visual images for a particular time, say 1 second instead of setting up with screen's fps, the signal should have th…
