Radha_openbci
Radha_openbci
- Radha_openbci
- United Kingdom
- 23
- United Kingdom
I don't use the Bias pin, what is that for?
I use NuPrep abrasion before applying Ten20 gel. Yes, I am saying that my peaks could be due to the reference electrode on the mastoid. My reference impedance is generally low. Probably I don't place it on the correct bone every time so could be con…
I tend to change boards if one behaves weirdly. I do get noises-same or different in both. I think I agree with you that board isn't the problem. I do place my reference electrode on the left/right mastoid, so that explains the issue. MAybe whenever…
I don't think its the local environment because the one that had initial errors are still behaving that way in another location. Now I am using brand new Ag/AgCl electrodes with Ten20 gel, same with both.
Just to be clear, I do not have any Cyton. These ae 6 channels because the last two are bipolar derivations from 1-2 and 3-4
Hi This is from Ganglion too and I am getting these bursts for the first time if I recall correctly. Now I have both the open BCIs I can check signals from both in the same environment. I use one if the other is producing noises. Whats the best way…
I connect it on forehead. Unfortunately it is not possible to test both simultaneously now as both are in different countries. I can test both in a month when i have them together.
Hi! Thanks for the feedback. But the same happens in now 4 different environments on all people. I don't know why the electrostatic buildup would happen even after opening the encasing. Before a month i was using another Ganglion and it seemed to w…
Now I remember the BP is always on. Nevertheless here it is: https://ibb.co/tQDDkvR https://ibb.co/2NjvR0B https://ibb.co/hLGMvYJ
I can share here the raw files of what I am referring to. No in the FFT everything goes higher during those dual peaks, actually sways up and then comes back to normal. In the GUI I don't switch on the band pass. Yes, it is fairly similar.
Now at least it is not sampling slow frequently, but the dual peaked high amplitude is my concern that happens abrubtly.
Both notch 50 Hz and band pass 2-35 . But the raw signals reflect it and despite the 50Hz notch on Open BCI GUI, it is evident always. I know the notch there is only for viewing . Radha
Well to troubleshoot the problem, we tried various things: 1. Changing electrodes doesn't help 2. Streaming LSL so could be a memory issue causing packets to loose, but NO, I have 32 GB RAM 3. Read on another forum that it can be a charge accumu…
I am running standalone open BCI v3.4.0 with open BCI hub v 1.4.5 , Ganglion on Windows 10 64 bit. I am trying to stream LSL from Open BCI but the GUI freezes. It did not freeze only once/twice in between. But it freezes now. any suggestions? Do I …
Link for older versions: https://github.com/OpenBCI/OpenBCI_Hub/releases?after=v1.4.0 shifitng to an older version of bcihub 1.3.9 resolved my problems of ganglion not seen on open bci.
