Qoz
Qoz
- Qoz
- UCSD
- 30
- UCSD
Hi William, Glad to see you're still on the forums helping after all these years! I applied this fix and it seems to have solved my issues -- thank you very much. I find it a bit strange that these problems emerged after years of smooth sailin…
@wjcroft Sorry, I did not thoroughly read this thread, I was browsing the forums on my phone and was just skipping through. I apologize for the lack of effort on my part. I have not made the full extent of my data and code public, but I plan on …
@wjcroft I haven't had a chance to investigate this further yet; the account which purchases equipment belongs to my director, and we've been very busy lately! I'll update this thread as soon as I find out more information.
@skiria8 if you wanted a good software solution for markers, I recommend the lab streaming layer (LSL). It's very easy to create an LSL stream from the Cyton using the OpenBCI GUI or OpenBCI_LSL, and you can acquire that data stream online for real-…
@wjcroft, I'll check the shop on an account which has made purchases, and I'm currently in an email chain with @Conor, so I'll update this thread when I get more information. That rationale makes sense, although it would be nice for us to have a…
Since this 'crimp nut' is still not offered on this website and I can't seem to find anything remotely similar anywhere online, has anybody successfully tested an alternative? I was considering buying some brass/aluminum spacers and soldering them t…
I used versions 1.3.9 of the Hub and 3.3.1 of the GUI. If somebody could find a link for this older Hub that would be wonderful; I couldn’t find one myself, just luckily had an old version on a hard drive. Might also be worth compiling the GUI you…
What versions of the OpenBCI GUI and Hub are people using? I was never able to get things working on the latest version of the Hub and used an older one, and have been using the May 2018 version of the GUI to acquire data using the CSR that came wit…
As an update, I did manage to get everything working. First, I reinstalled the CSR Harmony Drivers from a CD (luckily I found it lying around my lab since there doesn't seem to be anything available online). Then, I went into 'services.msc' via…
My system dual boots into Ubuntu 16.04 and I couldn't get it running on there either, so I wish you the best of luck.
I'm having the EXACT same problem as you. I've tried just about everything and I can't solve this. I'm continuing a project on the Ganglion that I successfully conducted a few months ago before reformatting my harddrive, which is frustrating.
Hello, I am getting a code 412 error after reformatting my machine. I know the board/dongle work properly because I collected data few months ago (before reformatting) and when I boot into Ubuntu and use hcitool lescan it shows the ganglion. Curren…
