Default Avatar
Peterl
Peterl
Username
Peterl
Joined
Visits
21
Last Active
Roles
Member
  • Alright wj...Im at a standstill. Ive tried using the prepackaged .con files  by changing the eeg input, adding the bandwidth filter as indicated in your blog tutorial, but no output appears. Im at a loss... The one alpha training protocol that someo…
  • does it matter whether bandpass butterworth or bessel, and what filter # do I assign to it?
  • wow. thanks again wj. going to try to fiddle with this now. Been tinkering with the brainbay as we go and its starting to make sense.
  • just saw your last post, wjcroft. will give bioexplorer a try., thanks again for all the help.
  • OK...I think I'm starting to understand wjfroft...Looking at the .con file that works, the EEG set up is for the OpenBCI board. Is there somewhere I can obtain pre-programmed .con files for OpenBCI? Or, how does one go about modifying the EEG input …
  • or a better recommendation for neurofeedback operations on OpenBCI?
  • huh. ok...just right click the eeg element, then replace it with a new set up? or is there another place I can find working neurofeedback con's for brainbay? I will go back to your tutorial and look for the directions for a hipass filter... thank you
  • The design I did get working was just the preset .con file in the link in my previous post. I then tried to load .con files that are prepackaged with brainbay, and fail.
  • hmm. now I've managed to get the .con file referenced in this post https://sites.google.com/site/biofeedbackpages/brainbay-openbci/brainbay2 working, and responding to the inputs from the leads referenced. I can't get it to produce the sound output …
  • Thanks again wjcroft! I did look over and follow that link as well.... When is use the command line to look for the TTYUSB using ls-l it acknowledges it is there, and the COM sym link seems to be established through wine. WHen I try to 'connect' und…
  • Thanks  for your quick response. The tutorial you referenced is one of those I've attempted, as well as reading through the Brainbay user manual. The place I'm hung up is on where, after loading a config and pressing play, it begins to stream what …
  • Ive downloaded the latest version of Brainbay (2.0), which does have a OpenBCI 16 channel,...but using that I get the same effect. I load a config file, set source to OpenBCI 16 channel...when I press play, it appears to play a prerecorded playback.…
  • Hi folks. I bought the OpenBCI 16 channel a few years ago, and just got back to trying to get it up and running. I hope someone can help me here... Im running on Ubuntu 16.04.02 Ive managed to install the OpenBCI GUI and get it working, communicat…
