Paul_K
Paul_K
- Paul_K
- Berlin
- 15
- Berlin
Thanks for the link William, I am still trying different approaches. Modifying the Ganglion firmware to return a "$$$" terminated String when the v command is called via serial, allowed me to select the device in the Open BCI GUI and start c…
Hi William, I checked the SDK Docs (using the web.archive.org :-) ) yet I could only find a full list of commands for the cyton board (including he extra commands added in later firmware versions). I was wondering which specific commands need to …
Hi William, I had a look at the Cyton Firmware and at least ported the data package format. Unfortunately the Open BCI GUI seems to do some further initialization procedure to connect to a Cyton board. Any chance there is a document of the i…
the application will be used to control a stepper motor driver, based on specific frequency bands (alpha and beta primarily), so it is a 'live' scenario.The GUI will not be used in the final application, but it will be tested for R&D phase and a…
Thanks for pointing out the LSL format, I was not aware of that so far. Will investigate that further.
Thanks a lot for your reply William, your answer implies that I chose this route in order to save a buck or two, that is not primarily the case. The Ganglion Board is a rather "closed" ecosystem with the default firmware. Even though the Simblee …
