Default Avatar
NinjaPotato
NinjaPotato
Username
NinjaPotato
Location
Bologna, Italy
Joined
Visits
2
Last Active
Roles
Member
Location
Bologna, Italy
  • Thank you for the reply. I'm trying to make the most compact package, squeezing the battery near the cyton board in a 3D printed enclosure. One thing I can't fin any info online is: does the cyton board itself has a bms chip? Can I directly plug a 3…
  • I was thinking of using a li-po battery to power the cyton. Is there a way to make a switching charging circuit with a micro-usb, so that I can charge the battery and then use it directly without having to unplug it everytime? Integrating both the …
  • Ok, I'll try with the O1 O2 Pz P3 P4, that's probably it since mine were located only in the front. In my case I just have one single "teeth" like sensor which could be suitable for that position to penetrate hair touching the skin. I was wonder…
