NikoKoro
NikoKoro
- NikoKoro
- Athens, Greece
- 44
- Athens, Greece
Sure I'll do it right away. Thanks!
Hello! I was trying to use the .accelStart() command, but I just get a "pending" promise. Also, the documentation for the NodeJS library mentions that the accelerometer is enabled by default. Below are the images of my code and output: Sho…
Hello again! I forgot to mention that a friend of mine was able to receive data using my bluetooth adapter and ganglion, but he had that 15% data loss that you mentioned in your post. Now I was thinking that because he plugged the adapter on a USB 3…
I am using the adapter that was provided to me along with the ganglion(CSR8510 a10) I have already tested the hci0/hci1 and the bluetooth is the hci1 device, which is the one I configured. The values displayed (with "echo" or "cat") are 9 & 10. …
Hi again! So I managed to write the values to the conn_min_interval and conn_max_interval file but the problem persisted. I decided to abandon that plan for now, and switched to the node.js library. I managed (with the help of a friend) to communic…
I tried to execute the commands above, but I couldn't even with sudo. I'll try again as root. Will post results! Thank you!
Hello and thanks for the replies! I managed to connect to the board through NodeJS. I also tried user.py again and it connects to the board, but I get the message "Warning: Dropped 1 packets" when I type something. I'm sorry that I ask this in a di…
Oh I see! Thank you very much! Back to work again.
