MitchM
MitchM
- MitchM
- Appleton, WI, USA
- 34
- Appleton, WI, USA
Just wanted to leave a message on here that after I reformatted my computer, I was able to get BrainBay to open properly. have not yet tested it with my Cyton yet, but I figured id pass the message along as today I will be attempting the tutorials y…
that is what I saw when i was doing my initial research before buying... currently im having issues with the wifi shield which i am told AJ will connect with me at some point on.. With my laptop connected to the wifi shield and nothing else the fo…
hmm, yes I can see why it would be better to use these. still id hate to have to lug my laptop around when you have a phone or tablet that could assist with recording the data on the go (driving walking) it create a bit of artifact noise as well, bu…
Yes actually I do. its since my main device is a high dp display. i can read things like the OpenBCI GUI. Seems it does not like any external monitors period as having it only use the external or primary (even unplugging the cable) still causes the …
sorry let me reword.. the app opens up, I have an icon in the taskbar (bottom of the screen) but i cant see anything from it... I thought it might be lagging when trying to load or slow load (not sure why but i have seen weirder things happen) I a…
here is what is happening. i tried installing the BrainBay installer from https://github.com/ChrisVeigl/BrainBay/releases i originally tired the latest v2.1 but i also juts tried 1.9.3. it installs just fine, i run the installed program. i see …
wait so I do not have to do a Fourier transform to the raw data?.... i think i'm confusing my self now so basically... 1. Cyton gets signal from electrode 2. stuff happens <-- not 100% sure on this part the coding for Cyton lost me a b…
I appreciate the recommendation and if i can get the program to work, i want to play with it No I have not yet, I will take a look though his site/blog as there is a lot here. I was hoping this info would be in the OpenBCI Docs but at least you a…
yes, https://sites.google.com/site/biofeedbackpages/function-map definatly has the 10-20 to 'general what region does' map i was looking for. however the info im looking for converting that number to the band waves is obscured by the BrainB…
William, Thanks again for your responses. at the very least its helping me parse though things.. *** Feedback modalities Yes I was a part of that type of feedback when i did my neurofeedback work. the reason I am working with lights is becau…
William, Wow! thanks for all this info, I hope others find it helpful also! It is starting to help me cut though the confusion of all this info and get to the core truth of things. (i still do plan to get the Dasiy module as it will give me a bett…
Mgtimm, I am an app developer who is actually on a similar path. I am typing an email now to you.
I only found it after a few hours of googling with no success and trying to think about what else might be causing the noise with the device. Multimeetering the lines were all as expected so i just stared at the graph, saw a lag, so started playing …
William, I actually figured out what was going on, and its not at all what thought (see Issue #349 In GitHub). I noticed that the configuration of widgets I was using on my laptop running the GUI would "lag" or stop reporting for 1-2 seconds" and…
