Mike
Mike
- Mike
- 164
Sounds great. When should we expect V4? Any rough estimation for that?
Thanks William. I'm not sure why a single LiPO at nominal 3.7V 500mAh shouldn't be sufficient for running the 32bit board. Did you try to run it? How long did it last? Your comment about the revised board sounds interesting. Any idea when are …
Yeah, I read what he wrote. That's why I asked, he probably has it already
Has anyone tried to evaluate Spark's Photon with ADS1299? Mike
Any of you tried to run OpenBCI 32bit version directly through a LiPO battery? Any issues with that? Thanks, Mike
Hi, Yes, as William said, I'm using Adafruit Powerboost 500C. Would love to hear any update on this issue. Thanks, Mike
Well, I'm still having issues with the OpenBCI device. Not very often the device suddenly start to transmit packets with sample counter = 0.Is this known issue? Has anyone reported on it?
One more thing - how would you differentiate between a packet that holds accelerometer data and one that doesn't? By default accelerometer data should be received at 25Hz(which also keeps changing... ) but if the data rate of the EEG changes repeat…
Hello William, I have read the post that you linked. I couldn't see any solution there. So, I was wondering if someone has figured out some way to overcome this issue. It is making much harder to do an accurate signal processing this way. About…
Hi, I'm experiencing some really strange behavior with OpenBCI sample rate. Does it make sense that the sample rate is over 250Hz ? I'm using the default firmware that comes with OpenBCI 8bit board. Any feedback will be appreciated. Tha…
One more thing I have just noticed that after half an hour or so I'm starting to get many missing packets - the counter is getting out of order.. I had a suspicion that maybe it has to do with battery power - so I measured the battery but it seem…
Hi Chip. Thanks for the detailed response. I actually tested this fix. I might have misunderstood, but the thing is that once I change the gain, you can see how the signal is zoomed and looks much bigger, which as far as I understand should not happ…
Hi Chip, Just wonder, wouldn't there be an issue with "VertScale" if gain is changed per channel yet the scaling for the display data is performed for all channels? Mike
Could that be the reason for the problem that I'm having?
Btw, what the sampling rate that you used? It looks like it is higher than 25 Hz?
Is it with 8 bit or 32bit board? I will give another run and see what are the results. This is so strange!
Hello, I'm using 8bit OpenBCI and I'm trying to make sense of the accelerometer data that I receive. I have been struggling with it for several days now in vain. I'd like to know if one of you could please confirm that OpenBCI's accelerometer wor…
I'm using 8bit board. I just downloaded to the board a fresh firmware and made sure that "OBCI.useAccel" is set to true. I get the same results. Very strange, the accelerometer is not sensitive at all to movements. I noticed that chip checked it aw…
Hi, 1. The OpenBCI device is still with its original firmware, I didn't update the code, so I suppose this flag is set to true ? 2. LIS3DH Registers: 0x07 0 0x08 0 0x09 0 0x0A 0 0x0B 0 0x0C 0 0x0D 0 0x0E 0 0x0F 33 0x1F 0 0x20 8 0x…
Hello Chip. I was wondering is there a need to set some flag in the firmware or send a command for enabling the accelerometer functionality? As far as I could tell from the firmware code, the accelerometer is suppose to be on by default. Howeve…
Different EEG devices might require different pre-processing procedures for the raw data and these procedures are greatly depend on the electronics that are used. So, that's why I believe that it is crucial to properly have some decent document/re…
Well, when system's core data is being processed (e.g. scaled, filter etc) wrongly I suspect this is considered a serious bug. As far as I understand, OpenBCI's UI is part of OpenBCI EEG solution and most people use it for analyzing and evaluating …
Hi, Can someone please answer my 2nd question. I suspect there is some serious bug there. Also, in the document below you claim that this value should be adjusted when amplification is changed. http://docs.openbci.com/software/02-OpenBCI_Stream…
Hi, This document says that the scale factor is a function of the user's selected gain, however, in the code the "ADS1299_gain" doesn't change even if the ADS1299 gain was modified. Would like to hear if there is some explanation for this behavi…
Very informative. Thank you.
Thanks William. I had a look on the OpenBCI code and it doesn't work as I expected - it doesn't have to use live lead off detection as far as I could tell. //compute the electrode impedance. Do it in a very simple way [rms to amplitude, t…
Hi William Well, as far as I could tell the impedance values during playback were pretty much the same as the impedance values that were computed during live session. That's why I'm surprised.Am I missing something here?
Hi, uVRMS is displayed for each channel during offline data playback, if I understand correctly this value relates to electrode impedance? (I usually used to see this values in kOhms). I'm a bit confused though of how is it possible to comput…
Thanks William.
Hi Just to double check again before I connect this booster (http://www.adafruit.com/product/1944) to 8bit BCI board. It seems that the board is accepting 6V-12V and the booster seems to provide 5.2V - So, my question is will it work correctly? …
