Marceloruiz
Marceloruiz
- Marceloruiz
- 24
Wow you were right!, I change my resolution and it display it correctly!, also when I use a big resolution (full hd) I right click in the gui icon, press move, and use the down arrow to move it on the screen and work also! thank so much @flyingcube …
Oh wow!, nice observation!, but I can't find the gui_showmenu.m, is a new file you added? or what version of BCILAB you have?
I cant solve it yet @flyingcube, the EEGLAB works great, but the problem is when I try to open de BCILAB...
Hey thanks! there is no need for BCILAB with this! just one more question the file openbci_pylsl.py that the doc reference, which one is in the OpenBCI_MATLAB/Matlab-Python/ folder? there is 3 filesopen_bci_v3.py openbci_matlab.py I cant find any …
Hi, I have the same problem, is there any solution for the newest version of Matlab? I cant see the toolbox, but I see there is an active window, looks like the toolbox (gui) is not visible
Wow! Finally I did it! Thank you so much for your help qwer1304!, the last step I did was using http://chipkit.net/wiki/index.php?title=ChipKIT_core from version 2015-10-18 because the last version 2016-1-10 - Version 1.1.0 (same code as URL install…
Yes I did, this is an Image of the error and the openBCI board selectedhttps://gyazo.com/700016ca0e9010e07cfd1eb52c26ac21
Oh, I cast the expresion not the Hex value, I did it in all errors I get, now I got the following error: pic32-g++.exe: error: C:\Users\Marcelo\AppData\Local\Temp\build314722887501305307.tmp/core.a: No such file or directory C:\Users\Marcelo\Docu…
I didnt understand well the casting part, for example the first error, isthis correct?data = _spi->(uint8_t) transfer(0xFF); or data = (uint8_t) _spi->transfer(0xFF); I still getting errors in this line :S, how did you cast? and also did you…
I got the same problem, but didnt work the solution qwer1304 try, is there any official solution? why I cant compile the code?
