MCube78
MCube78
- MCube78
- 32
@pushtheworld Hey AJ, ok so it turns out I also had to update the Processing OpenBCI gui! Now that I've both updated to beta4 AND updated the OBCI_GUI for processing it looks like it is recognizing modes. Only thing, unlike what is said in the docu…
Hi @pushtheworld yes, I had installed Beta2. I ran DefaultBoard from the Beta4 folder, but when I launch the GUI (from processing) and try entering '//' or "/2" (which I assume is what the documentation meant, instead of "~2" which is for the samp…
thank you @pushtheworld I downloaded the library and (I think) I successfully uploaded the default_board firmware as said in the guide. When I launch the GUI from Processing I can see a response to when I type commands like '~5' and ':' in the d…
Hi @wjcroft @pushtheworld I've made a post as you suggested: https://github.com/OpenBCI/OpenBCI_GUI/issues/155 I tried to include all that I could recall, feel free to ping me if I omitted anything that can be of help! thank you martin
Hey @aala out of curiosity do you have Win 10 too? (@wjcroft)
Thank you @wjcroft for the answer. I've tried it on both a desktop (Dell XPS Win 10) and a laptop (ASUS Win 10). It is a brand new OBCI system, so I have just downloaded the FTDI drivers on both computers following the tutorial. And yes, I have fol…
Same/similar problem here.. I just got a cyton&daisy, all the updates software etc, and seem to be stuck at a no-communication dead end too -- I keep getting a failure to poll device/failure: system is down/etc. Like you I tried installing t…
As a followup to the above, the problem really seems to be that the board appears as if it were off or otherwise disconnected. When, from Processing, I start the OBCI GUI and try connecting and starting the system I get the following error: openBCI…
Hey there, I just received my brand new Cyton&Daisy (and I'm a complete newb to all of this), but I seem to be stuck on the same issue as the OP. I tried installing the Radio Config utility, but it gives me the same error: "Communications tim…
