Katie888
Katie888
- Katie888
- Canada
- 37
- Canada
Hi wcraft, exactly, thank you very much for your support and patience!
Hi wjcroft So I just ran the Ganglion, this time with more Ten20 paste, and the impedance was only: Channel[0] 15.00 and Reference Impedence 18.00 and the 'rms Uv' was only 47.9 But out of 5 seconds the voltage peaked at over 200 uv each tim…
Hi wjcroft You are right. I exchanged the dry electrodes for some wet electrodes (Channel 0, Reference and Ground), spooned and taped them together and then ran the impedance with this result: Channel[0] 000.5 Reference Impedance 0.05 A…
Hi wjcroft Not sure if they were shorted. I attached the ground and reference to the OpenBCI EEG Headband right next to the one channel 0 electrode. Is that the correct way to short? And it turns out that the Ganglion has had this problem all a…
Hi, thanks for getting back to me so quickly! So per your advice I put the channel 0 electrode, reference, ground together and checked impedance and it is very high. So to be on the safe side I powered up the battery, but the results (see below) …
Hi, thanks for getting back to me so quickly! So per your advice I put the channel electrode, reference, ground together and checked impedance and it is very high. So to be on the safe side I powered up the battery, but the results (see below) we…
Hi wjcroft, I tried your idea, but unfortunately did not work, and retiutut I also tried the beta, but also did not work. So I tried reinstalling my windows 10 to fix any windows problems, but that too did not work. I really appreciate your help, …
And part 3: Suppressed: java.io.IOException: Native library (win32-x86-64/BoardController.dll) not found in resource path ([file:/C:/Users/lcumm/OneDrive/Documents/My%20Documents/00-EEG/z-OpenBCI_GUI-v5.2.2-2023-08-21_16-14-34_windows64/lib/L…
And here is part 2: Native library (win32-x86-64/BoardController.dll) not found in resource path ([file:/C:/Users/lcumm/OneDrive/Documents/My%20Documents/00-EEG/z-OpenBCI_GUI-v5.2.2-2023-08-21_16-14-34_windows64/lib/LSLLink.jar, file:/C:/Users/lc…
Hi wjcroft, here is the console, part 1: Console Log Started at Local Time: 2023-12-21_06-22-33 Screen Resolution: 1920 X 1080 High-DPI Screen Detected: false Operating System and Version: Windows - 10.0 JVM Version: 1.8.0_202 Welcome to the Proc…
Hi Richard and wjcroft, Good news, I got out my old laptop and tried it there and it saved to the BDF file no problem. And when I clicked on "Stop Session", it DID take me back to the "System Control Panel", so that could be a clue as to what …
Hi Richard and wjcroft I just noticed that when using the OpenBCI-GUI that there is a difference when I choose the OpenBCI (csv) versus the BDF file. So when I choose the OpenBCI (csv) file, and then get to the point where I click on the "Stop t…
Thanks wjcroft, I just tried that, but no luck
Oh I see, thank you! So looks BDF briefly did work, and then stopped working for some reason.
Also, in case this helps, yesterday the bdf did work briefly, but the results were very damaged, here is a snippet: ÿBIOSEMIX X X X X X X X X …
Thanks wjcroft. This seems to be a rare issue, but hopefully Richard has some ideas.
