KMO
KMO
- KMO
- 8
Yes, I tested the ADS1299 results in term of noise and the internal pulse generator by using Kst and Qt creator (Qcustmplot) to plot the data. So, I have coincident results by the datasheet. I can have blinking signal and Alpha wave by using these G…
Thank you very much for your answer and suggestions. In fact, the problem is, I have some sort of saturation at +-500uV no matter of the scale of the oscilloscope. Even if I change the oscilloscope range, the level of the signal remains at 500uV o…
Hi,I have a problem of using BrainBay with ADS1299. I used a different microcontroller in my design and I sent the data with the same protocol as the OpenBCI. Byte 0:0xA0 Byte 1:Packet Counter (i=i+1) Byte 2 EEG Channel 0 (high) Byte 3 EEG Ch…
