Default Avatar
Januz
Januz
Username
Januz
Location
Philippines
Joined
Visits
52
Last Active
Roles
Member
Location
Philippines
  • Thank you very much for the inputs.
  • Greetings, I have done this: @wjcroft said: There is a simple test you can do with one or more channels. Just connect the channel(s) together with a blob of paste or alligator clips, and also include in that bundle the SRB2 reference and…
  • Others suggested that my data could be picking up residual (and unwanted) cardiac signals, since the counted spikes converts to approximately 96 beats/min. They suggested for the stream to be cleaned, however it could also affect the neural signals …
  • @wjcroft said: Then you are NOT using Wifi Shield, but the original Bluetooth-Gazelle radio protocols. So that makes the spikes you are seeing even more unexplainable. Many of the clone makers are shipping nested boards that include the former Sh…
  • Greetings, thanks for replying. I'd like to quickly ask if these things that you've recommended is applicable even if I'm using an USB dongle in connecting the board instead of connecting via Wi-Fi? Since the shield component I only have is the Dais…
  • Hi, thanks for replying. I indeed bought it from a local electronics shop, and they said something about it being 'homebrew' and that's what we can afford for now. Any clones using Shield-like components will be subject to these anomalies. …
  • @Fuyuki, can I see your Streaming Bar Plot Node Window? Mine's looking like this, and I haven't encountered that specific error. However, even if my pipeline does not output errors anymore, it still doesn't classify correctly. I'm wondering if the…
  • Update: The folks at Neuropype told me to use the Select Range node to eliminate any unused channels that might interfere with the CSP ML model and it worked.
  • Greetings, @Doc_Slater can you please send me the .xdf Calibration data coming from @rakeshbci01? I already asked him but it seems that he is busy at the moment. I could compare Mr. Rakesh's calibration data file to mine, and per event using Inspect…
  • Greetings. I'm following the motor imagery tutorial on the website using Neuropype and Cyton via this link: https://docs.openbci.com/Examples/EEGProjects/MotorImagery/. The EEG and the LSL stream seem to be recognized by the lab recorder and the mot…
